주요 콘텐츠로 건너뛰기
Samsung의 열 번째 주력 핸드폰, 2019년 3월 출시. Android 9.0 (Pie)와 함께 제공됩니다.
63 질문 전체 보기
How much heat from a hairdryer to loosen adheasive?
im trying to take off the back, i feel like im heating it too much but i cant get the back to open up. I really need help because i dont want to damage anything. First time trying to repair
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
how long i mean
댓글 달기
답변 2개
선택된 답변
Heat up the phone until it is almost too hot to hold constantly in your hands. I usually use some heat resistant gloves to counteract that. Keep your heat gun moving around the back glass and don’t keep it in one spot for too long. It takes quite a bit of heat to burn adhesive but it’s very possible if you keep your heat gun concentrated in one spot. Keep the gun moving around the back glass for 5-10 minutes usually and you can grab a suction cup and gently pull up the glass just enough to get a prying tool in to work it around the glass.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi XMeee, I have done many Samsungs, including the S10. Although there is no exact number to heat at, a good recommendation would be to heat it so it is just barely too hot to touch with your bare hand. Overheating is much less of an issue than you think! I would rather overheat the phone than underheat and crack the glass. :)
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
ive done it to the point I could not hold it and i still never got a slither of gap
댓글 달기
귀하의 답변을 추가하세요
xMeee 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 126
