iPhone 6s doesn't charge but shows it's charging
My iphone doesn't charge. It was all working before. I tried using multiple power bricks, plugging it into a pc, restarting, cleaning the charging port with a soft toothbrush and nothing fixed the issue.
The weird thing is if i plug it in the wall it shows its charging, sometimes it charges 2% and stops, and if i plug the brick out of the socket it wont stop showing it charges.
as you can see it displays that it is charging
The battery indicator number also changes a bit randomly.
I am using some 3rd party charging cable without mfi. I replaced a screen on it before. Battery has maximum capacity of 83%.
I think it could be problem with either the battery, charging port or simply the cable.
Sorry for my english.
좋은 질문 입니까?
댓글 3개
Ok, finally a good mfi cable arrived and i did some tests, turns out it isn't the tristar. I think it's probably how HelloMacOs said and it's the battery. Isn't there anything else that coulb be causing this issue? Also before the battery completely died it changed percentage a lot, from 2% to 13% and than it died.
Bot64 의
I'm so sorry for wasting everyones time, it was probably me being stupid and not connecting the battery well enought, after i reconnected the battery it charges, so far its on 29%. Im so sorry.
Bot64 의
You don’t need to be sorry
Because you had a issue and you did the right thing coming to the right place
So please do not be sorry about it
HelloMacOS 의
