주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
MacBook optical drive in iBook
Can I replace iBook G4's optical drive with one from MacBook (A1181)?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
If one of these answers fixed your problem please hit the "accept" in list that has "History Edit Flag Accept Comment" located to the upper right of your question so we can remove it form the unanswered list.
의견 추가하세요
답변 3개
선택된 해법
MacBook drives use the same PATA interface until the Early/Mid 2009 models.
Regardless, iBooks use a full-sized drive, and the MacBooks use slimline drives, so they are not compatible. Sorry!
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
가장 유용한 답변
They're definitely not inter- changeable. The iBook uses Pata connector and the A1181 uses a sata interface.
해당 답변은 도움이 되었습니까?
점수 3
댓글:
Are you thinking of hard drives? The A1181 uses the same interface until Early 2009 models.
You're right Ben, good eye!!! I was thinking hard drives. Thanks for the pull_up!!
의견 추가하세요
As you can see here, I don't believe that the drives are interchangeable.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
teeeveee 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,096
