주요 콘텐츠로 건너뛰기
Garmin 스마트워치 수리 안내서 및 지원.
Garmin's Forerunner 55 Battery Replacement, is it possible?
I’ve just realized that my recently bought Garmin Forerunner 55 has no apparent way to replace it’s battery.
Am I wrong?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
In theory it should be possible, but just by what I can find on it online it’s going to be difficult to replace. Just by looking at the device I can already tell you’re going to need an opening pick and maybe a heated device to soften any glue holding the screen in place.
Although, assuming that you can get into the device then you’ll need to find a replacement battery. I couldn’t find a new one online, but I’d be willing to bet if you contacted Garmin’s support they would put you into contact with their battery supplier. Otherwise you could maybe cannibalize an old Garmin for its battery.
No more adhesive battles! With our iOpener, you can quickly and easily remove glued components in electronic devices whether you're a repair professional or beginner. Apply gentle, even heat to loosen the adhesive holding smartphone, tablet, and laptop case components and batteries. 이미지
제품
iOpener
$24.99
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
So to give you the Spark Notes of it. Is it possible, yes. The question is, is it worth it?
댓글 달기
답변을 추가하세요
Fernando Alves Reisen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 26
지난 30일: 96
전체 시간: 3,291
