주요 콘텐츠로 건너뛰기
First generation of Apple iPad with 3G capabilities. Model Number A1337. Available with 16, 32, or 64 GB of storage. Repairs are straightforward and do not require heat.
89 질문 전체 보기
replaced glass now touch screen not working?
Hi I used the guide here to replace the broken glass on my ipad. I have completed the reassembly apart from clipping the glass into the frame. I tested to see if it was working before clipping it back into one piece..... only to find the ipad powers up fine but the touch screen now isn't working....... can anyone help?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
의견 추가하세요
2개의 답변
선택된 해법
Check again the digitizer cable. Take it out and use "contact spray" on the contact. I always use contact spray on these kind of contacts. Typically inserting the display cable in unibody MacBook Pros I find often the backlight does not work. I take out the cable, use a little contact spray on the contact and cable and insert it and it always works. Make sure the little retaining flaps are pushed down. A good investment is contact spray, technical alcohol and a air spray can. They always come in handy.
해당 답변은 도움이 되었습니까?
점수 5
의견 추가하세요
Make sure that the 2 white guidelines on the digitizer flex cable are pushed as far as they can be into the connection on the logicboard.
Don't forget to power it off before you start though.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Debbie Dean 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 2,434
