주요 콘텐츠로 건너뛰기
The Dyson V8 Animal is a cordless vacuum equipped with powerful suction that can last up 40 minutes on one charge.
12 질문 전체 보기
My dyson doesn’t hold a charge for long also when using it plusats
My dyson v8animal plusates when using and doesn’t hold a charge for long yet it has 3 full blue lights showing I have also replaced the battery but made no difference
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
It probably just needs filter cleaning. The pre filter on the top can be pulled out and rinsed with tap water. My V8 had similar pulsating problem and lost suction power. Replacing battery didn't help. Then I found out that yt was just a clogged filter. Cleaned it and put it back. Problem solved! Works as good as new.
댓글 달기
답변 2개
가장 유용한 답변
Dyson V8 Animal Battery Replacement
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Check that you inserted the screws tightly after replacement. It could have been a bad battery at first, but then you probably replaced it and inserted the screws too loosely after putting in a new battery. If not, it is perhaps that you are using Max Mode too much.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Charlotte mallard 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 234
