주요 콘텐츠로 건너뛰기
A2116 / 2019 / 3.6GHz 쿼드 코어 i3, 3.0GHz 6코어 i5 또는 3.2GHz 6코어 i7 프로세서. 2019년 3월 19일 출시.
73 질문 전체 보기
Can I install a blade SSD in my HDD-model iMac?
(CPU - 6-core i5; RAM - 8 GB; GPU - radeon pro 560X - 4 GB)
Hello! I have an iMac (specs screenshot above), I would like to upgrade it (CPU (i9-9900), RAM (32 or 64 GB)) and notice HDD to SSD. When I started to crash in this process, I had questions:
1. Do I have this slot for Blade SSD? (My iMac has Fusion Drive 1.03 TB installed)
2. Can I solder a socket (the photo above, this photo is not mine) for the Blade SSD and will it work?
*Sorry for my English :c
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Sadly, its a bit more than a connector there are a few other components needed as well.
Time to look for a used Fusion drive'd system and then swap out the CPU with yours if you have the more powerful version and add the blade SSD. Or just get a replacement logic board like: 21.5" iMac Retina 4K Logic Board 3.2GHz i7, SSD, Vega 4GB
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
but my iMac had Fusion Drive 1 Tb + 32 Gb. Can i install blade ssd?
@Петр Бионенко - If you bought a Fusion Drive'd system then you have both the SATA & Apples custom PCIe/NVMe driver connectors!
Here's the guide you'll need to follow iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement to swap it out, I strongly recommend you stick with either an Apple blade SSD or go with OWC's
You could also just replace the SATA HDD with a SSD drive as well (disabling the small blade SSD as it gets in the way)
I recommend OWC,
I upgraded my 2012 Macbook pro, 2009 Mac pro with there parts,
Still a beast
https://eshop.macsales.com/item/OWC/S3DA...
댓글 달기
귀하의 답변을 추가하세요
Петр Бионенко 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 58
