주요 콘텐츠로 건너뛰기
JBL tuner dab/fm is Frozen
I tried to do a factory reset on my JBL tuner. I plugged into my acer chromebook. Everything was going fine until I was going to eject. I must have clicked in the wrong place , because the usb connection dropped. Now the display shows : " No update file" My speaker will not respond in anyway, regardless of which codes I try. Also it will no longer connect by usb.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Well the saga continues.
I let my speaker stand for two and half days until the battery was empty. I then charged it up - With a full battery I once again tried to do a factory reset. I powered up the speaker. Took my very best usb cable and plugged into my acer chromebook.Once again I received the message about the update. This time I was very careful where and how I clicked.I proceeded thus; alt+right clicked. The correct sub menu appeared. Eject usb.
This I did. But to my dismay, instead of switching off , I once again watched the same message appear on the display.
" No update file " and as before it was frozen. It would not power down or do anything ,regardless of which codes I tried to enter.
But I am very stubborn and will not give in. The battle of dominance continues. This little jewel will conform.
.Resistance is Futile !!!
댓글 달기
답변 2개
Disconnect from the laptop, press and hold 4 buttons at once, {DAB/FM} + {VOLUME-} + {BT}+{VOLUME+}, worked for me.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Piepmatz 83
Ich hatte heute das gleiche Problem beim JBL DAB Tuner 2: Batterie voll, aber trotzdem "Nichts geht mehr". Dann suchte ich die kärglichen Bedienungsanweisungen. Dort fand ich in Klammern im Kleinstdruck: Reset auf Werksauslieferung: Blutooth und 1 gleichzeitig mindestens 10 sec. drücken. Hat funktioniert!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
gary wicks 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 178
