주요 콘텐츠로 건너뛰기
The Xiaomi Redmi Note 8 is a mid-range smartphone by Xiaomi released October 2019. It has a 6.3" IPS LCD display, a 48 MP main camera, a rear-mounted fingerprint sensor, a 4000 mAh battery, and runs on a Snapdragon 665.
22 질문 전체 보기
My phone is locked by itself and won't turn on.
My phone is off and won't turn on even though I press the power button and volume up button. My little boy threw it on the ground, is that why? Can you tell us the best ways we can? I don't want to give it to the phone guy.
Contact: ardik.0 (Instagram)
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Did you try plugging in the charging cable and seeing if the screen lights up? Do this to check if the phone is functioning or not
댓글 달기
답변 1개
가장 유용한 답변
Try to charge the device. If nothing shows up and you don't hear the plugged-in sound, your best option is to open up the phone and disconnect and connect the battery again.
If you hear the phone charge but nothing shows up, you need to get the screen replaced.
In case, if disconnecting the battery method didn't work, then you should consider get the screen replaced and then troubleshooting it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Arda İsmail Kayaoğlu 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 321
