My sensory is broken
The sensory on the front of the Oculus quest 2 moved a little to the side on the bottom left and the bottom right one moved down and its causing problems with my tracking. Is it possible to fix?
좋은 질문 입니까?
좋은 질문 입니까?
bots Not depends on how it moved. If there is anything bend that may make it a bit trickier. Take a look at these guides Oculus Quest 2 to work on it. Specifically. I would suggest that you check this guide Oculus Quest 2 Disassembly and see if you are willing to go that route. Here is a good video on replacing a camera (should get you to the sensors as well) and shows you how to work on it.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 408
