주요 콘텐츠로 건너뛰기
The Mavic air with its glorious camera, this drone is a great start for beginners to learn how to fly.
2 질문 전체 보기
How to revive a battery that has totally died.
I can't charge the battery of my Mavic Air, first generation. It went down to zero during flight.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
If this has a Li-Ion (lithium) battery you can try this procedure at your own risk (these batteries are explosive and handling near sparks can be dangerous have fire extinguisher nearby in rare case of emergency) splice and expose two wires of an old known working 5 volt 9 volt AC DC charger adaptor using a voltmeter test the ends to confirm positive and negative. Then quickly and carefully tap the respective ends of your battery usually positive is indicated by red wire or a nippleend of battery.Tap the ends repeatedly for at least 30-60 seconds in effect these jolts of current can wake up a dead battery or charging chip that cuts off energy to device when battery is too low to safely recharge. If you EA are not experienced enough configure out this method you can also connect your battery or device to existing charger and try plugging and unplugging the charger from socket several times in same manner. This is not 100% successful all the time but many times it can be and it's free so totally worth a shot Good Luck
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thanks, I'll try it out.
댓글 달기
귀하의 답변을 추가하세요
Moe Lwin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 55
전체 시간: 1,972
