주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1963 질문 전체 보기
iPhone 3GS Antenna Cable
does the antenna connector have the number 7 on it, lower right hand side?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
PC 노트북 배터리
큰 전력 향상을 위한 손쉬운 수리.
지금 장보기
PC 노트북 배터리
큰 전력 향상을 위한 손쉬운 수리.
지금 장보기
2개의 답변
선택된 해법
Yes, I believe that is one of the antenna connectors. You can see it in step 10 of this guide.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
Just wanted to provide some more details because I had to deal with this myself just this past week:
In the 3GS, the #7 connector is for the Cellular/WWAN antenna sticker which is on the back of the lower dock assembly (the rest of that assembly is for the mic, speaker, and charge port through connector #4). Please note that the WiFi and Bluetooth antenna sticker is separated and part of the top assembly and connected to the logic board through #6.
This contrasts to the behavior of the earlier 3G model, which had a single antenna sticker on the lower dock assembly for Cellular/WWAN, WiFi, and Bluetooth (WiFi & Bluetooth was in the top left, Cellular/WWAN was in the bottom right of the sticker - you can clearly see the separation). Additionally, there was no #7 connector, so my "assumption" is that the #4 connector handled all of that in the earlier model.
Hope that helps! In my case, I pulled off what appears to be a resistor (not sure, too small) near the #7 connector while pulling up the warranty sticker. Thankfully, I'm using this older phone as an iPod Touch, so everything works great for me even though I did that.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
slarso 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 3,060
