주요 콘텐츠로 건너뛰기
2009년 중반기 모델 A1278 / 2.26 or 2.53 GHz Core 2 Duo 프로세서 EMC 2326
740 질문 전체 보기
Fan goes max when you start computer and Wifi hardware not found
I've changed the harddrive and removed the cd rom. When I noticed that the new harddrive didnt work I put the old hdd back. After that change the fan goes max when I start the computer and after 5-8 min the computer shuts itself down. To add to this problem when I changed back to the old hdd the wifi doens work I get the message "hardware not installed" on the Icon message.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Starting with the WiFi problem: Did you damage the camera data cable or not correctly connect the cable? Review this guide Steps 5 ~ 7 MacBook Pro 13" Unibody Mid 2009 AirPort Card Replacement
  • What was the drive you put in? Make and Model
  • Why did you remove the optical drive? If you put in a second drive what did you put in?
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
I could connect the cable, didnt se any damage on in. I did not put in any new HDD just removed it.
The new HDD was a Hitachi 320 GB SATA standard 2.5" 9,5mm 5400RPM.
When I disconnect the camera data cable the fan goes normal.
@rubl - Then you have a short in the cable or the connector is damaged.
As far Hitachi drive what is the exact model as some of these drives won't work in your system correctly.
Why did you take the optical drive out? I would put it back in. Leaving it out alters the systems structure and offers an unprotected entry for material to enter.
The hitachi drive model is 5k500 b-320 , type TS5SAA320.
@rubl - The good news is this is a SATA II (3.0 Gb/s) drive so its a perfect drive for your system. But its an older drive ;-{
It maybe on its last legs if its' been in use all of this time. Do you have an external FireWire case to install the drive? See if that works. Today we need to be careful as many of the newer drives are just too fast for this system.
댓글 달기
귀하의 답변을 추가하세요
Ruben Cañas Lindh 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 38
