주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.0GHz, 2.3GHz, 또는 2.6GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.8GHz).
580 질문 전체 보기
Internal Speakers and Headphone Jack not working. Bluetooth does work.
While working on some music production, my sound suddenly stopped working. I would use bluetooth but much of my work requires a higher fidelity than bluetooth allows. Both USB and HDMI are viable options except those ports are often needed.
It seems that when using the headphone jack to do a line out to a pre-amp for my headphones it caused something to happen that has since disallowed my speakers (internal or headphone jack) to work. When trying to adjust the volume it shows a prohibitory symbol (a circle with a slash through it). When looking in System Preferences > Sound > Sound Effects and then on the drop down next to where it says "Play sound effects through:" internal speakers or headphone jack (when something is plugged in) is not an option.
I'm wondering if there is a part that can be replaced or if the audio components are part of the Logic Board. I see that it is possible to change the speakers and microphone, maybe something else. I'm lacking confidence about any of those things fixing my issue.
I have tried all of the software options (PRAM reset, etc), that I know about, some more than one time. Thanks for assistance.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Within the headphone jack is a set of switches as you can see in this mechanical model and within the systems schematic
What often happens is the contacts get misaligned or dirty. Yo do need to be careful as your jack is also optical interface! Using a TOS-link cable.
I would recommend going with the optical connection Vs the electrical connection.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Tyler Shafer 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 191
