XS Max - back glass BROKE. What should I do?
I have the option to get a $30 back glass replacement, or a $100 back housing replacement. Since this is a rather old phone, I want to spend a minimal amount. Will glass replacement be okay?
좋은 질문 입니까?
좋은 질문 입니까?
back glass replacement is fine depending on who is doing it and what method they use to remove the old glass
해당 답변은 도움이 되었습니까?
The rear housing is what virtually every other part in the phone is mounted on, so replacing the rear housing isn't just any old part swap, but more like a complete disassemble and rebuild of the phone. If you can get away with just replacing the rear glass, definitely a far better option. As long as the case isn't bent or distorted, the glass can be professionally replaced to where you would never know it had been broken.
해당 답변은 도움이 되었습니까?
depends if its a pulled housing or a copy, copy back glass or glass of similar thickness. genuine housing with copy port. all leads to if its done by a good tech it should be fine
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 66
