주요 콘텐츠로 건너뛰기
모델 A1200 with 2.16 또는 2.33 GHz Core 2 Duo 프로세서
111 질문 전체 보기
removed dvd drive, now fan goes on indefinitely
HI
i had to remove a faulty dvd optical drive due to crazy noise, iam planning to order a replacement but what is happening now is tat the fan is going at full speed, right from the start up, is this normal?
hi i have a iMac 24 inch (white) 2.33Mghz core 2 duo, ((((i dont see no ECM number on the label so i cant say if i am giving you correct info)))
Here is what was in my system profile:
Computer details
Model Name: iMac
Model Identifier: iMac6,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.33 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 4 MB
Memory: 2 GB
Bus Speed: 667 MHz
Boot ROM Version: IM61.0093.B07
SMC Version (system): 1.10f3
PIONEER DVD-RW DVR-K06:
Firmware Revision: Q609
Interconnect: ATAPI
Burn Support: Yes (Apple Shipping Drive)
Cache: 2000 KB
Reads DVD: Yes
CD-Write: -R, -RW
DVD-Write: -R, -RW, +R, +R DL, +RW
Write Strategies: CD-TAO, CD-SAO, CD-Raw, DVD-DAO
Media:
Type: DVD-R
Blank: No
Erasable: No
Overwritable: No
Appendable: No
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
you guys are right, i did forget to reconnect a thermal sensor, its in my hand :( with the old drive.
Thanks allot
댓글 달기
답변 2개
선택된 해법
Sounds like you forgot to reconnect a thermal sensor, there are quite a few of these throughout the computer, and forgetting the reconnect them will result in the computer thinking that it is overheating, and reving the fans up to full speed. Thermal sensors ususually use 2-Pin connectors, and can be easy to forget to reconenct.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Recheck all your connections
esp. the ones to fan and heat sink. You could have one that "looks connected" but isn't, or you may have damaged a connector.
Good Luck,
N.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Gabriel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,843
