iStat Pro Report - Rear Main Fan 0 rpm
iBook bottom has always been extra hot. Recently replaced battery and DC in board. Runs great, but needs a thermal blanket. Should I replace the fan, or is more troubleshooting needed first.
좋은 질문 입니까?
좋은 질문 입니까?
Good job and thanks for coming back to share solution.
Found an excellent app - G4FanControl 0.6.1. Resets threshold settings. iStat now shows 8200rpm. Much cooler too. carlstaff, Feb 1 @ 10:42 PM
This answer needs to be accepted or voted up.
N.
해당 답변은 도움이 되었습니까?
Do you hear the fan when you watch videos on youtube or when you do intensives jobs ? If no then replace the fan. Cheap repair.
해당 답변은 도움이 되었습니까?
AKA- Flash
Most likely that istat is just not compatible with your iBook..
Their website advises that it doesn't work with most PPC Machines..
해당 답변은 도움이 되었습니까?
I highly doubt that it's a false positive.
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 1,620
댓글 2개
carlstaff 의
Hi- good job solving it yourself, can you please though put this comment as an Answer instead and them Accept it so we can see what worked? Thanks.
rab777hp 의
