My eject button broke, how can I still eject without it?
Ive tried EjectDvD, but it doesnt detect a dvd even though its inside. It might be since the wheel circled is locked down and the disc wont fit in bc of it.
좋은 질문 입니까?
좋은 질문 입니까?
@pponthep if it is your disk that is crooked in there it probably jams the drive. Not sure what you mean by the wheel and how it is locked. The drive should normally eject the drive after you unplug it and then apply power to it again. Post a larger image with your QUESTION. This seems to be a bit small for my eyes:-)
You do want to check on the loading mechanism. Check something like this video and for the eject button itself check this Ultimately it looks like you need a new drive for your Wii
해당 답변은 도움이 되었습니까?
Thank you kindly for your answer, this is a recently bought drive. first test worked well, but my eject button broke halfway, so i resorted to sliding the disc from behind the drive. its still in the position it was when i put it in, and my discs can fit if i put force into it, but not enough for the wii to suck it in. The wheel im referring to is listed below. What im trying to find out is if i can get the dvd drive to open up without the eject button, which is not inside the wii at the moment
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 63
