주요 콘텐츠로 건너뛰기
The Lenovo IdeaPad 330-15IGM is a slim and compact laptop.
1 질문 전체 보기
How do I fix my laptop from sticking in black screens cursor or locks?
After typing my password it just loads and does nothing, it shows the blank screen and that's it. I tried power shut down holding the button for 15 seconds, tried f2 f9 f10 thing just nothing works
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Does it display the lenovo logo?
Which OS are you running?
Pressing F1 or F2 repeatedly during boot (normally right after you see the logo) Should get you into bios though it may take multiple tries. If that doesn't work try creating a boot disk on USB on another device. Has the BIOS been updated?
댓글 달기
답변 2개
  1. Try a Windows Key Sequence to Wake the Screen.
  2. Open Task Manager to Restart Windows Explorer.
  3. Roll back the Display Adapter Driver.
  4. Uninstall your Display Adapter Driver.
  5. Perform a System Restore.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
It sounds like your user profile may be corrupted. You could try CTRL+ALT+DEL and open task manager from the security prompt if it opens. In task manager click File -> Run New Task. Type Explorer.exe into the dialog box and hit OK, the desktop should launch.
If that doesn't work then I would try to get into safe mode from the log in screen:
  • "Get to safe mode from the Windows sign-in screen:
  • On the Windows sign-in screen, press and hold the Shift key while you select Power Circle with line Power icon > Restart.
  • After your PC restarts to the Choose an option screen, select Troubleshoot > Advanced options > Startup Settings > Restart.
  • After your PC restarts again, select the startup setting you want to use.
  • When you're done, exit safe mode by restarting your PC. If that doesn't work:
  • Press the Windows logo key Windows logo Start button + R.
  • Type msconfig in the Open box and then select OK.
  • Select the Boot tab.
  • Under Book options, clear the Safe boot checkbox."
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Phiea 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 128
