주요 콘텐츠로 건너뛰기
식기 세척기 수리와 분해 안내서 및 지원.
702 질문 전체 보기
replaced main control - same F2 E2 error
2021 Whirlpool dishwasher - 15 months old - just past warranty :(
parts look just the same as shown here...power surged and then the e2 f2 code started flashing
I checked connecting wire continuity - OK
replaced user interface (with buttons) board - same F2 E2 error
repairman proposed same solution...
time for new dishwasher!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
@indycarl your DW is a Whirlpool WDT720PADM2? Just to verify, You did replace the main control module?
댓글 달기
답변 1개
@indycarl this is tough since we do not know what your repair person checked etc. Usually all you have to do is to:
  • Removed the front panel.
  • Checked 4 pin connector on the P1C connector on both the UI board (thin PCB that interfaces with the buttons) and the main control board (larger control board where all the colored wires interface)
  • On the same connector measure the voltage between pin 2 and 4. It should show ~5V.
  • .If there is no voltage replace the main module
  • If there is 5V replace the console.
Your DW should be using the W10610059 tech sheet. Just in case you do not have it, get it here W10610059 Tech Sheet W10610059 Rev B
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
IndyCarl 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 25
전체 시간: 840
