주요 콘텐츠로 건너뛰기
First Manufactured: Dec 2011 Sync master 20 inches with a resolution of 1600 x 900. It also has an option like Magic angle and magic tune.
HDMI Port repair & Replacement
No display an image into the monitor by using an HDMI port
how do i repair & replacement plz help me
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
How do you know it is the monitor and not the computer that is at fault?
love kesh try all the other input sources and see if those work. Your monitor is a Samsung 20 inch monitor S20B300B?
댓글 달기
답변 1개
가장 유용한 답변
  1. Make sure your computer can actually display the image. If you are using a custom PC and have a discrete GPU, make sure you are plugging it into the GPU instead of the motherboard. If that doesn't work and you have an iGPU (integrated GPU), try plugging the HDMI into the motherboard.
  2. If none of the above works, check your HDMI pins. Look into the port (on the PC and the display) to make sure that none of the pins are broken. If a port on the PC is broken, try using (if you have) the other ones. Most PCs come with multiple HDMI ports.
  3. Make sure that everything is plugged in, and test the display with another computer.
  4. If it still doesn't work, you may need to get your monitor or PC (depending on which is broken) repaired/replaced.
If there is anything I missed in this answer, please let me know!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
love kesh 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 18
전체 시간: 512
