주요 콘텐츠로 건너뛰기
2011년 7월 21일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Thunderbolt. 이 기기는 Mac mini Server 구성을 실행하는데도 사용됩니다.
231 질문 전체 보기
Broken ir connector(?), possibly to run without?
Hi,
I have successfully managed to detach the what i think is the ir connector from the logicboard. And therefore I can not connect the wire with 5pins onto the logicboard.
Can anyone please confirm that the cable is intended for the InfraRed function on the Mac mini server 2011?
And please say that I can use my mac mini server without that cable!? Or must I send it to service?
Thanks in advance!
Fredrik
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글:
It is hard to give you an answer without pictures of what is broke off and where it is located on the board. You have the ability to trace where the wires that connected to the header lead. If you are not sure what they go to, we can't be either.
의견 추가하세요
답변 1개
선택된 해법
If you can do without sleep and some other functions - they are, I believe, included on that sensor.
Remember to return and mark accepted the answer that best solves your problem.
해당 답변은 도움이 되었습니까?
점수 2
댓글:
Was wondering if anyone had pin assignment info for the IR header, and sensor info. Thanks in advance!
의견 추가하세요
귀하의 답변을 추가하십시오
Fredriknoren 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,410
