주요 콘텐츠로 건너뛰기
Released in May 2020, the 13" MacBook Pro features quad-core Intel 8th generation Core i5 and i7 processors, and Intel Iris Plus 645 integrated graphics. (Model A2289/EMC3456 with two Thunderbolt 3 ports)
56 질문 전체 보기
Damage to back of laptop lid
I bought a cheap laptop cover and it appears to have damaged the aluminum "lid" of my laptop--I'm totally blanking on the proper word right now, sorry about that.
Is this lasting damage I should be concerned about, or will it be okay as long as I never use this style of laptop cover again? This is actual buckling and warping you're seeing, not a scratch.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
2 댓글:
Does the system still function correctly and the display is clear?
@danj Sorry, didn't get a notification for this! Yes, it's fully functional and there are no problems with the display or sound.
댓글 달기
답변 1개
Your only option to fix this if the display is not working is replace the display assembly MacBook Pro 13" (A2289, 2020) Display Assembly and here's the guide MacBook Pro 13" Two Thunderbolt Ports 2020 디스플레이 어셈블리 교체
Update (07/06/2022)
@Mikey Lewis - This is what I call an edge case! While it's working now the air gap to the LCD panel and the distortion of the defuser sheets is now reduced. So a bang along here could damage it to the point of needing a new display assembly.
For the sake of giving you a view internally review this great teardown of the retina display which is using the same basic construction in your series MacBook Pro Retina Display Teardown. Unlike it the T-CON is located within the main body with the signals going across a set of ribbon cables.
MacBook Pro 13" (A2289, 2020) Display Assembly 이미지
상품
$494.99
MacBook Pro 15" Retina Display Mid 2012 이미지
안내서
난이도:
Moderate
MacBook Pro 13" Two Thunderbolt Ports 2020 디스플레이 어셈블리 이미지
안내서
난이도:
Moderate
1 - 2 hours
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Mikey Lewis 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 31
