주요 콘텐츠로 건너뛰기
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
207 질문 전체 보기
No cold water on wash but rinse is fine
I have no cold water going into the machine on the wash cycle. Rinse cycle fills just fine with cold. Took hoses off and checked inlet screens—they are fine. No problem with house supply. Anyway like I said there’s cold on the rinse but none on the wash.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 9개
Hi,
What is the model number of the washer?
Model number is MVWB300W02
It definitely seems like an electrical or computer issue.
that sounds like corrosion on the valve not allowing cold and hot water in that or some gunk in there blocking the flow i need more info
do u have heavy water or high content of minarels in the water such as calcium, sulfides, or even led cuz that can do the same thing too over time
Martha Wright which wash cycle are you using? If it has cold in one cycle but not the other, it is unlikely that this is a water supply issue. This sounds like a wash program issue.
댓글 4개 더보기
댓글 달기
답변 2개
가장 유용한 답변
Hi,
Here's the Tech Sheet W10374149 Rev A for the washer.
Run the automatic diagnostics as per p.1 and check if a C2 error code occurs. If it does follow what it states in the C2 Recommended procedure section to find the problem.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
u have a bad or malfunction water temperature switch
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Martha Wright 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 127
