주요 콘텐츠로 건너뛰기
Repair and support for ceiling-mounted bladed fans.
33 질문 전체 보기
I can hear the motor humming but the blades won't spin, the lights wor
When I turn it on I can hear the motor humming but the blades won't spin, the lights work fine. The fan is only a little over a year old?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Hi @sabelle,
Is it possible for you to take it down from the ceiling and then upload a few pictures? If you could get some detailed pictures of the motor, it would help. Adding images to existing questions.
댓글 달기
답변 1개
선택된 답변
Sounds like maybe the start capacitor has gone bad. The motor will jump but if the lil black start capacitor is bad the motor won't start and run but to test this you can turn the fan on and then try starting it by spinning it kind hard with your hand. If it starts and runs then you cap is bad!
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
You can also check capacitance with a cap checking meter or a multimeter that will read mfd. But based of what you described, yeah... bad capacitor. Easy to replace though, and cheap online. Just make sure you get a replacement with the same value and number of wires. If moving the blade doesn't get it to go the cap could still be the issue! A weak cap will let the motor run if started by hand. But a completely dead one might not.
댓글 달기
귀하의 답변을 추가하세요
Richard Dilbone 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 57
