주요 콘텐츠로 건너뛰기
Released 2016, this Sharper Image stunt drone is rechargeable and has a 150-foot flying range. It is black with 4 propellers. It has a 2.4GHz transmitter. It requires no FAA registration and includes charging cable and (4)replacement blades. It has removable blade guards.
30 질문 전체 보기
Flew my drone in my pool will it ever work again thank you for your co
Flew my drone in the pool will it ever fly again thank you for your
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Have you removed the batteries? Opened it up to clean out any water that got inside? The longer the water sits in it, the greater the chance of corrosion.
댓글 달기
답변 1개
가장 유용한 답변
It will basically depend on if you tryed to fly it immediately after it being in the water and how much water for into the actual motors and in the electronics. If you allowed it to dry good before turning it back on the. You might get lucky because I would assume that drones do have some sort of water resistance!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Michael Souder 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 20
