주요 콘텐츠로 건너뛰기
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 질문 전체 보기
I need help buying a headphone jack for my 60gb model
I am looking online for a replacement headphone jack for my ipod and the only seller i could find lists them as "thin" or "thick" instead of 30gb or 60gb. I have a 60gb model and I don't want to spend a lot of my money on import fees and the sort. Which one is the right one?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi
On the iPod if it says thin it means 30GB and if it says thick it means 60GB
You can find these sorts of parts on eBay and AliExpress
Sorry but I cannot provide links to the items as I don’t know where you are from
Hopefully this answers your question
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
"Thick" or "thin" has to do with the physical thickness of the hard drive. The 30GB drive is thinner than the 60 and 80GB drives, so the rear case has to be correspondingly larger to accommodate the extra size.
That, in turn, affects the dimensions of the components mounted on the rear case, including the battery, hold switch and headphone jack.
@dadibrokeit
That’s exactly it:-)
댓글 달기
귀하의 답변을 추가하세요
timuriu 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 37
