주요 콘텐츠로 건너뛰기
Repair and Disassembly guide for the 2020 ASUS G15 G512LI, A laptop produced by Asus for budget/light gaming.
21 질문 전체 보기
My laptop is acting funny.
I need help. My laptop sometimes acts weird like, I can't click anything but my mouse still working and able to move on screen. It usually happens when I'm switching tabs between software. my laptop sometimes also suddenly mouseclicking and scrollclick on itself. I've updated windows/GPU and drives but still happening. need help
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 5개
I also have the same issues. My laptop don't work at all for a while. But after that, it works well. What should I do to recover this issues?
@larrymurray
If your having the same touchpad issues as the OP above, try the answer below to determine if it is the touchpad or something else.
@jayeff Yeah, touchpad. I'm a little bit confused. Should I need to replace my laptop touchpad?
@larrymurray
Did you try what was suggested in the Most Helpful Answer below?
If disabling the touchpad and using a USB mouse stopped the problem from happening, it looks like there is a problem with the touchpad.
Yes, I figured it out later. My touchpad didn't work.
댓글 달기
답변 1개
가장 유용한 답변
Hi,
Disable the touchpad (Fn+F10) and use a USB mouse connected to the laptop to navigate and check if the problem is still there or not.
If it doesn't happen, it may be that the touchpad is intermittently faulty and producing "ghost touches".
Has the keyboard/touchpad gotten wet at all?
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
the same thing is still happening even after I disable touchpad, do you know any other reasons as to why this is happening?
@Kenzie Retro
Try starting in safe mode and check if the problem still occurs.
I am truly sorry, i've been trying to access safe mode but I don't think I can get the bitlock recovery key, which won't allow me into safe mode. Do you have any other alternative way to fix this? or should I just reset my laptop?
@Kenzie Retro
Here's a link that may help/ Hopefully it applies to Asus as well.
To be safe maybe backup the drive to an external drive before you do anything else. That way your data is safe if it goes pear shaped.
댓글 달기
귀하의 답변을 추가하세요
Kenzie Retro 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 432
