주요 콘텐츠로 건너뛰기
Released November 2016, the PS4 Pro features upgraded hardware for 4K gaming and improved PSVR performance.
352 질문 전체 보기
Power Supply motherboard connector
Hi,
I was trying to clean my PS4 Pro and change the thermal paste while following some guides on the website.
When it came to the part of disconnecting my power supply, i use some plyers because the cable was stuck and i couldnt even wiggle it off.
Well, the full connector came of the board. Im attaching some pictures. Is there a way to fix this?
Thank you
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 4개
선택된 해법
yes it will require a soldering iron, solder, flux and a thin conductive wire
Update (07/18/2022)
the point with the blue circle is the pad you are missing so that red line will be the wire, you will have to scrape some of the green coating away from around the small hole at the end of the red line and thats where the wire should connect to
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Do you have any pointers on where i should connect the conductive wire?
댓글 달기
circled red now as you must of misread me saying the red line inside the blue circle
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Just to see if i understood this one, (please refer to the image attached), i soulder points 1, 2 and 3 and solder a wire from point a to point b on that single red line so that it replaces the missing pad?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I did misread, apologies.
So it's like this, 1, 2 and 3 soulder to the connector and then red line (conductive wire) goes from that circle that i have to scrape to the last connector?
Sorry for my confusion but im kinda taken aback by all of this
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Sérgio Oliveira 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 15
30일 전: 58
전체 시간: 285
