The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
288 질문 전체 보기
How to install airport card in Mac pro desktop 2009 8 core
How do I install airport card in 2009 Mac pro Nehalem??
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
2개의 답변
선택된 해법
It's located right on top of your logic board and you just take the screws out and snap a new on in like RAM. For the correct procedure and part please give us the last three figures of your serial number.
해당 답변은 도움이 되었습니까?
점수 3
댓글:
Apple Mac Pro "Eight Core" 2.8 (2008) Specs
Identifiers: Mac Pro Early 2008 - MA970LL/A - MacPro3,1 - A1186 - 2180
Remove the two screws holding it in place. Snap off the antennae connector, pull it straight off the board (it's in a socket connector). Do you need the part number?
의 답변
No thanks Mayer, I got the part already.
Thanks for your help
의 답변
의견 추가하세요
Also, here are some images that might help you out. The main trick is dealing w/the connectors. I had to hold the card in my right hand at an angle and with thumb above and index finger above the card snap them in place. Also, the card I bought didn't come w/screws (Apple brand) which is weird. Make sure you use cable 1 & 2 and connect them to the 1 & 2 on the card. It is pretty hard to find, but it is there.
higher resolution images:
Note location of card after installation
close up of card - before insertion
close up of card - once connectors are on card and in place
close up of card - after insertion
Jamil
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
hagar24 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 6
전체 시간: 5,846
