Replaced Logic board, worked for a couple months, battery now dead
I needed to replace my logic board as the original one had issues (https://developer.apple.com/forums/threa...) and was successful in doing so.
I used my MBP for a couple months post install and it worked great. Just recently, the battery life has been nonexistent and needs to be plugged in via USB-C or the laptop will shutdown.
coconutbattery reports:
- Current Charge: 0 mAh
- Full charge capacity: 208 mAh
- Design capacity: 3.1%
- Cycle count: 152
- macOS Battery status: Poor
I double checked the contacts from the logic board to the battery controller and it looks ok to me. I can confirm that the battery isn't charging since I checked it with a multimeter and it showed around 2V.
My suspicion is that the problem is with the (new) logic board -- anyone else think so too?
좋은 질문 입니까?
Can you post the CoconutBattery screen so we can get the rest of the info. 기존 질문에 이미지 추가하기
I would stay given the age of your system you may just need a new battery.
Dan 의
Question edited with image. I don't think the battery itself is of issue since it retained charge normally before I replaced the logic board. Maybe the battery controller?
aluminum robot 의
