주요 콘텐츠로 건너뛰기
The iRobot Braava Jet M6 was released on July 12, 2019. It is a robotic mop that can map out rooms and cleans floors by spraying water and mopping with a pad attachment.
Irobot brava can't unlock buttons after wifi pw reset
Changed home wifi PW but the buttons on Brava m6 were pet locked. I can't get back into the my to unlock buttons. Need to press to buttons to reconnect to new wifi.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
I have the same problem... Have you find any way to fix it?
Unfortunately not yet
댓글 달기
답변 2개
가장 유용한 답변
This worked :To turn Child & Pet Lock off without the app, tilt the robot so that one wheel is pressed into the ground (the wheel springs are fully compressed) and the other is floating in the air (the wheel springs are extended, not compressed). While holding the robot in this tilted position, press the CLEAN button 3 times. You will hear a sound and the light ring will illuminate white for 3 seconds to confirm.
You will be able to hear a chime sound once you have disabled Child & Pet Lock with the appropriate button combination.
이 답변이 도움이 되었나요?
점수 8
댓글 7개:
Once you hear the chime, hit clean button one more time
Awesome tip!!!! You solved my problem!
The iRobot rep didn't know this trick for the M6 Braava. He said that trick was solely for the J series robots. He thanked me for the new info. Thank you for the tip.
It really works! You just have to tilt it on an angle high enough. It works! Thank you 🙏
Excelente ♥️
댓글 2개 더보기
댓글 달기
Tengo una roomba i3 con conexion wifi, la configuré con la app con bloqueo para mascotas/niños, pero ¿qué pasa si pierdes el móvil o como a mi, te cambian el router y la configuración wifi es nueva????. pues que la roomba se queda bloqueadda ya que no puedes pulsar los botones para conectar el bluetooh y que te la detecte el movil, suena un odioso mensaje "los botones están bloqueados use la app para limpiar"
Correo a soporte y la solución en spanish:
En primer lugar, para desbloquear los botones, siga estos pasos:
Teniendo el robot fuera de su base de carga, incline el robot de modo que la rueda derecha quede presionada contra el suelo (los muelles de las ruedas están totalmente comprimidos) y la otra flotando en el aire (los muelles de las ruedas están extendidos, no comprimidos).
Mientras sostiene el robot en esta posición inclinada, presione el botón CLEAN 3 veces. Escuchará un sonido y el anillo de luz se iluminará en blanco durante 3 segundos para confirmar.
Al conseguir desbloquear el robot, acceda en su aplicación móvil - Configuraciones del robot - Configuraciones Wifi - Cambiar wifi del robot y siga los pasos para vincularlo con el nuevo router.
While holding the robot in this tilted position, press the button 3 times:
  • Roomba® i Series, s Series and, Braava m Series: CLEAN button
  • Roomba® j Series: single button
이 답변이 도움이 되었나요?
점수 4
댓글 달기
답변을 추가하세요
George Salcedo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 54
전체 시간: 5,859
