주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The PSP 3000 was released in the U.S. on the 15th of October 2008.
The X button isn't working
I just excavated my PSP 3001. I'm currently cleaning it, but when I finished making sure all the grime was gone, the X button started not to function. I cleaned the sensors, and every button except for X has a little delay here and there, but they work. Is there something I'm missing or did I do irreplaceable damage?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
What do you mean, excavated?
The x button is working by itself
댓글 달기
답변 2개
What I would do is get a replacement x, square, circle, triangle pad (the thing that you cleaned). They’re fairly cheap on Amazon.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
A potential solution exists for the issue you're experiencing. On the right pad, where the "O" button is situated, you'll find a small bent tab connecting the upper and lower parts of the pad. Essentially, when these connectors make contact, it registers as a click, corresponding to the button you're pressing.
It's possible that the X button is consistently registering as pressed. To address this, consider placing a narrow strip of paper next to the X button, avoiding the rounded dot in the middle but positioning it directly adjacent. This adjustment should disrupt the constant connection, allowing the button to activate only when pressure is applied, thus resolving the issue.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Patrick McCarthy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 20
지난 30일: 72
전체 시간: 2,209
