주요 콘텐츠로 건너뛰기
Model A1174과 2 GHz Core Duo 또는 Model A1207과 2.16 또는 2.33 GHz Core 2 Duo
212 질문 전체 보기
Where are the Diagnostic LED's on a EMC2105 iMac?
I have a iMac emc 2105 20" model that will not power on. I have removed the case cover and am trying to locate the diagnostic LED's . There does not appear to be any LED's just to the right of the ram slots visible.
Where are the Diagnostic LED's and what do I have to remove to locate and see them ? I have found numerous references to other models and the diagnostic LED's but not this model.
I have found what might be a LEd on the "bottom" of the unit to the right of the RAM slot, but this is what might be a single LED, certainly not a row of 4 of them are present.
My real problem is that the machine will not power on and I am trying to diagnose whether it is the power supply or the motherboard.
Does this model have a SMC reset button ? If so, where?
Does this model have a internal power on button. If so, where ?
I was hoping to reset the SMC before I went any further -- how do I do that.
There is NOTHING glowing anywhere that I can find. I have not removed the back cover, only the front bezel and screen. I have replaced the backup battery ( Cr2032 on the motherboard). I have tried cmd+option+shift + pwr button reset -- -to no avail.
A pointer to a previous thread that answers this question and provides diagnostics for THIS model would be helpful.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
You're looking in the right place. They may be covered up by a small piece of black tape that comes up from the bottom edge of the logic board. See if you can locate the tape and remove it.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Paul Lodrige 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 6
전체 시간: 1,395
