주요 콘텐츠로 건너뛰기
Apple은 MacBook Air 13"를 2017년 6월에 새로운 Broadwell Intel Core i5 프로세서로 업데이트하여 성능과 배터리 수명을 약간 향상시켰습니다.
423 질문 전체 보기
MacBook air won't startup unless power button held on for long time.
Hi there! Same problema here MacBook air won't startup unless power button held on for long time. with my 2017 13" Mac Book Air.
This happened all of a sudden and my problem is perfectly the same as written by the first user who had posted years before I did.
What is the solution, pls?
Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Your system is going into an SMC latched condition! Let's get some better diagnostics of your problem as it could be a few different issues!
First install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 기존 질문에 이미지 추가하기 as often the batteries get long in the tooth.
Second, I would run the onboard diagnostics to see if a firm error code is generated. If it does let us know what it is. To enter into diagnostics restart your system and press the D key to enter!
Reference: Mac startup key combinations
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
javier_degiorgio 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 15
