주요 콘텐츠로 건너뛰기
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
207 질문 전체 보기
Clean cycle starts at 1:04 (hour and four min).Only last seven minutes
Clean cycle will start with an hour and four minutes, after it fills its skips the wash and rinse dropping down to four minutes. Its not even long enough to dissolve the affresh puck.
I hear water go in and can feel the hot and cold coming from them. Then it’s just done. Anybody have any pointers?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Hi @fenwood,
What is the model number of the machine?
Hey @jayeff It’s model is mvwb450wq2
댓글 달기
답변 1개
가장 유용한 답변
Hi @fenwood
Try disconnecting the power from the machine for about 5 minutes and check if this resets it at all.
If still no good, here's the tech sheet for the washer.
Try running the diagnostics as described and check for any error codes.
Hopefully this is of some help.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Greg nowak 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 58
