주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Bose Wave Radio AWR1-1W, also known as the Bose Wave Radio I, was released in 1993. A countertop AM/FM radio system with a high performance stereo tuner and two independent alarms.
Bose Speaker noise sounds like Thunder
Intermittenly when I turn on my radio, the speaker noise sounds like Thunder. This does not happen all the time, and the only way to make it go away is to turn the radio off, and then turn it back on. Although, not even doing this will always work.
Any ideas of what this might be?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Hi
If the audio is distorted or could be a SOC on the main board but we should leave that as a last resort
I would open it up and check for any bulging or popped capacitors ,also if anything looks strange I would check it with a multi metre to check if there is a short of some sort
Also try reseating any connectors (possibly cleaning them with isopropyl alcohol as you go)just in case it’s a dodgy connection
And check if the issue persists
If the issue persists let me know and we can look into in further:-)
Hopefully this helps
Any questions please ask
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Coy Callender 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 331
