My Xbox got wet not turning on and making noise in the power supply
My Xbox got wet with water and not turning on and making noises in the power supply.
좋은 질문 입니까?
좋은 질문 입니까?
Never turn or leave on wet electronics. If you are lucky, you might have just shorted something out. Disassemble everything and clean out with isopropyl alcohol. Don’t waist your time with rice. Most likely something in the PSU or motherboard shorted. There is a chance it is dead though if you turned it on when wet.
해당 답변은 도움이 되었습니까?
Maybe put it in the rice. It helps to get the water out:)
해당 답변은 도움이 되었습니까?
Rice does nothing except make a mess and waste time. Use some silica gel or take it apart and use a hair dryer too dry it.
@ln038 please do not suggest Rice for any repair. Rice will not do anything to fix things. It will not stop corrosion and it will not clean any organic residues. If nothing else, read through this Don't Put Your Device in Rice. Here's Why...
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 58
댓글 2개
Can you upload a picture of the motherboard in your Xbox? 기존 질문에 이미지 추가하기
Andrew S 의
sounds like the power unit may have a short
hay yew 의
