주요 콘텐츠로 건너뛰기
Released in May 2020, the 13" MacBook Pro features quad-core Intel 8th generation Core i5 and i7 processors, and Intel Iris Plus 645 integrated graphics. (Model A2289/EMC3456 with two Thunderbolt 3 ports)
56 질문 전체 보기
Pop sound when closing the screen after a repair
So I had to change the backlight which made me remove the screen after I put everything back up again
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Loosen the hinge screws slightly as the hinge pins are not in proper alignment. then snug them slowly checking if the pop sound is gone.
해당 답변은 도움이 되었습니까?
점수 0
2 댓글:
I don't get is there any toturial explains it
Sorry guy nothing that gets into the art of repair. The MacBook Pro 13" Two Thunderbolt Ports 2020 디스플레이 어셈블리 교체 is assuming you follow the reverse. Often things just line up, sometimes not!
This is no different then a house door! The pins of the hinges need to be within the same line. So if you just mount the hinges on the replacement door at an angle the pins won't slide in when you fit the door into the frame, that is if the hinges are at the correct distance from each other.
Get a metal ruler to help you in the alignment.
댓글 달기
귀하의 답변을 추가하세요
omar alaa 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 29
