Which Thermal Paste Brand?
Just curious as to which thermal paste would you use? I used Arctic Silver. That should be fine right?
좋은 질문 입니까?
좋은 질문 입니까?
Hi
This is quite a unpopular opinion but aslong as you are using a good quality thermal paste it doesn’t really matter
Most people will use arctic silver or thermal grizzly but I use jut whatever I have on hand as thermal paste is quite subjective for what you are using it for
Some might say one is better that the other for GPUs or lidded or unlidded CPUs ,it’s really what’s you personally find works
So aslong as it does the job you should be all good to go!
Hopefully this helps
Any questions please ask
해당 답변은 도움이 되었습니까?
So even for the Xbox it wouldn’t matter? Be the exact same as a desktop CPU I guess.
Well kinda
All thermal pastes do the same thing really
It’s what ever people finds works for them :-)
Yeah I kind of figured. Just read somewhere, that someone said you shouldn’t use Arctic Silver on the Xbox so was curious. I have Cooler Master and Arctic Silver. Anyways, thanks for the reply.
I've put arctic silver ceramique2 on probably 60+ series x post HDMI replacement at this point. Works great on them as it does for everything. Don't use it in a ps5 obviously. That liquid metal is a must, but also doesn't need replaced anyways unless you accidentally spill or wipe it off
24 시간 전: 4
7일 전: 33
30일 전: 182
전체 시간: 2,147
