주요 콘텐츠로 건너뛰기
Xbox Series X는 마이크로소프트의 차세대 4K 콘솔 게임기 입니다. Xbox Series X는 2020년 11월 10일에 Xbox Series S와 함께 출시하였습니다.
67 질문 전체 보기
What hardware would cause stuttering?
I’ve noticed tiny stutters when moving the screen and frame drops on certain games on the Series X. If it was due to a faulty component, what component might that be? SSD? CPU/GPU? And where would you get such replacement parts? Could it be just the game itself? Could it also just be a faulty console update?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Nobody knows, Xbox is a fully encrypted and un-debuggable unit in retail mode.
Are you sure it is not just bad game coding? Does the issue happens on the same game with every Xbox?
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
I don’t have a spare Xbox Series X to try. Some games run better than others. However there are issues with some games stuttering when you enter a new area which leads me to believe it’s an SSD problem. I replaced thermal paste so it can’t be an over heating issue. Not sure as well if it’s solely due to the fact I’m on 60Hz instead of 120Hz.
@kain05 Still sounds like expected behavior to me.
댓글 달기
귀하의 답변을 추가하세요
Kane 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 346
