주요 콘텐츠로 건너뛰기
The 2018 version of the Samsung Galaxy A7 smartphone released in October 2018.
51 질문 전체 보기
Dropped my phone screen is black but the notification are still coming
Hy. So my phone split of my hand and hit the floor it was about 50 cm after the screen was black i could hear the notification but the screen was black my phone has glass protector the screen is not DAMAGED pls help.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Hi,
Just because the screen appears not to be damaged doesn't mean that it didn't suffer any internal damage that is not visible e.g broken connection in the display panel.
As a DIY repair all you can do is to temporarily replace the display assembly and check if it works or not. This is to find out if the problem is in the display or on the systemboard.
Here's the ifixit Samsung Galaxy A7 (2018) Display Assembly Replacement guide that will help.
Search online for Galaxy A7 (2018) display assembly to find suppliers that suit you best.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
You could try to force restart the phone by holding the volume down and power button until it restarts. You should feel a vibration when it is turning back on.
But most likely the screen is damaged. The glass may not be cracked but the OLED underneath the glass probably is. So a screen replacement would most likely be the solution to your problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
sᴘᴏʀᴛ ᴄᴇɴᴛᴇʀ 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 40
전체 시간: 1,253
