주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1500 질문 전체 보기
Which Parts Exactly Do I Need to Order?
I have a 3GS with a visible hairline crack, and pixels dying in a wide horizontal line at the bottom of the screen.
Which part or parts should I order to repair both of these problems?
Does the "Display" include both the glass and what one would think of as a traditional display? Or are there two parts needed.
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 5개
선택된 답변
Ifixit has the parts you need for this repair.
[연계 제품이 누락 또는 비활성화 됨: IF142-002]
NOTE; I just noticed that it is currently out of stock. But, you have an option to have them email you when the part comes in, I'm pretty sure it wont be long before they get it in.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I was worried it was the assembly. Guess I'll wait until June (as long as I can read the screen that long) to see if a new phone is released as the repair is the same cost as a new one.
Thanks!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
No problem. Good luck!
댓글 달기
Scott, would you be interested in selling it?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Sorry, it's my only phone - and while the screen is mucked up it still works. So, I intend to keep it until a new model is released.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
You need an LCD and Digitizer. My understanding is the glass is cracked and the gray lines you see are actually damage to the LCD screen underneath.
You can buy and entire midframe assembly with glass, LCD, home button, proximity sensor assembly all pre-assembled on eBay and this would be the best route if you are not mechanically inclined. However you may not be getting "orignal" Apple parts, so read carefully. Always look for OEM or original quality assemblies if available, there are a bunch of garbage 3rd party parts out there so beware of imitators, calling it junk is an understatement! Also, not all that say "OEM" actually are. Look for words like "Genuine" or "Original" in the listing and the Apple name (properly spelled too, APPIE doesn't count!) will be on some components.
If you buy just the digitizer (with 3M adhesive) and LCD this will be least expensive route to repair (probably have about $75 invested for both "genuine Apple quality" on eBay), but you'll be in for some skilled disassembly to get the old digitizer from the midframe without damaging the rubber dust seal or other components of the midframe. FYI... I have an iPhone repair shop in Columbus OH. and I charge $150 parts and labor to replace both LCD and Digitizer on the 3Gs with 100% genuine Apple parts. Yes 1/2 that cost is labor, it will take time and patience to do it right!
Again I can't stress enough the importance of "original" or "true OEM" high quality parts. I have a over 3 years experience now and have worked with many vendors learning the hard way about variances in parts quality. Your digitizer should bear the Apple name on the flex cable. Look closely at photos before buying anything from eBay and stick with US sellers to avoid long shipping times and return hassles if you receive damaged goods.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Scott 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,430
