Where is the oil filter and how do you replace it?
How do you replace the oil filter?
좋은 질문 입니까?
좋은 질문 입니까?
You can access the oil filter by using some run-of-the-mill ramps. It is a cartridge type filter, that fits inside the housing. This factory part number is 04152YZZA1. You can check for instructions and illustrations right here. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
The oil filter is located in the engine compartment, it needs to be changed while on a lift as you cannot access it any other way. Once the car is on the lift, you should be able to spot the oil pan and locate the oil filter. Also, the oil pan may be hidden by a plastic shield... At any rate, changing your oil and filter is not a repair for anyone who does not have access to a car lift. Refer to your owner's manual to see which oil it uses and I would recommend taking the car to a lexus dealer or any oil change garage.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,229
