주요 콘텐츠로 건너뛰기
The Samsung Galaxy A31 is a mid-range Android device released by Samsung in April 2020. Identifiable by model numbers SM-A315(F, F/DS, G/DS, and G/DSL).
61 질문 전체 보기
Why I turn to my phone to landscape mode my display touch is to week
When I turn to my phone landscape my display touch response is too weak
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 5개
@achukutty what exactly do you mean by "to weak"? Is it actually working or only in certain areas?
Display not working on certain areas
But I can play games with third party apps
@achukutty is it always the same area that gives you trouble? Does that same area give you trouble in portrait mode? You have no problems with this in third party apps?
@oldturkey03 no only landscape mode
Yes no issues on third-party applications
@achukutty if you have no issues when using third party apps it will not be hardware related. Check your settings and you may have to reinstall/update your firmware. I suggest you check sites like this one or on here
댓글 달기
답변 1개
가장 유용한 답변
One of the best ideas I've seen for diagnosing touch screen problems is to bring up a drawing app, preferably one that will work full screen, and attempt to draw over the entire screen. The areas that aren't responding to touch won't be colored in so you'll get a visual idea of exactly what's not working.
In your case I would try it in both portrait and landscape mode and see if there's an actual difference.
Once you've done that, add pictures of the results to your question and we'll see what you've got there.
기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Achu kutty007 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 181
