주요 콘텐츠로 건너뛰기
Released in May 2020, the 13" MacBook Pro features quad-core Intel 10th generation Core i5 and i7 processors, and Intel Iris Plus integrated graphics. (Model A2251/EMC3348 with four Thunderbolt 3 ports)
20 질문 전체 보기
MacBook erased, but won't boot after xartutil --erase-all comm
After erasing the MacBook, I also wanted to erase the Touch Bar. However, after the command
xartutil -erase-all
My MacBook does not start anymore. The screen no longer lights up or turns on. Tried all reset commands. How do I get him to work again?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
You'll need access to another TB Mack system to run the Apple Configurator 2 app to try to re-install the system firmware. Here's more on it How to install Apple Configurator 2 for macOS
Basically, putting the system into DFU mode
Try running both Revive and Restore options
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
Thanks for the answer. When i erased the macbook it worked fine. but after the command xartutil-erase it is complete dead and i also get i not in DFU mode. is ther another solution maybe....?
@maxgeertsen - Your system uses firmware which is stored on the drive which you erased! What made sense in older systems creates issues with the newer models.
The other option is visiting an Apple Store who have a tech that can reload the firmware partition.
Hello, I also deleted the touch bar and I have the same problem as Max@geertsen.nl, did anyone manage to restart their macbook after turning it off? Thanks
@rorovd83 - As I explained you need a second system to run the Apple Configurator 2 tool.
댓글 달기
답변을 추가하세요
Max@geertsen.nl 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 13
지난 30일: 18
전체 시간: 1,025
