주요 콘텐츠로 건너뛰기
Apple의 2020년 주력 iPhone은 10월 23일에 6.1" OLED 디스플레이, 듀얼 12MP 카메라 시스템, 그리고 다석 가지 색상으로 출시되었습니다. iPhone 11의 후속 제품입니다.
Is it easier to replace the back glass, or the entire back housing?
The back glass on my iPhone 12 is broken, and it needs to be repaired so I can trade it in. I don’t have a laser machine. Would it be easier to replace the back glass, or the entire back housing? I think that replacing the back housing might be easier, because I won’t have to destroy the back of my phone more.
Thanks in advance :)
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
getting the glass changed by someone with a laser maybe a cheaper option than buying a housing, you would probably need an original housing for a trade in and they would probably be the more expensive option
이 답변이 도움이 되었나요?
점수 4
댓글 5개:
Okay cool. Sorry for the noob question but what specs would the laser need?
@isaacnaylor do you mean what power is the laser diode ?
like i don’t know anything about lasers
i know someone w/ a laser engraver, but i think that an engraver and marker are different. like isn’t there a certain wattage or something?
@isaacnaylor most lasers for back glass are between 6-8w, i dont use 1 personally i use a hot air station to do back glass replacement. i will add a photo to an answer to show you an iphone x i did
ok thanks so much
댓글 달기
답변을 추가하세요
Isaac Naylor 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 30
전체 시간: 785
