주요 콘텐츠로 건너뛰기
2010년 4월 출시 / 2.4, 2.53 GHz Core i5 또는 2.66, 2.8 GHz Core i7 프로세서
593 질문 전체 보기
MacBook Pro 6,2 won't run off of a fully charged replacement battery.
I replaced the battery in my 2010 UNibody 15" Macbook pro. The replacement battery has fully charged, but the computer won't fun off of the battery.
When it's plugged in, the batter indicator lights as well as apps like Battery Monitor show a full charge and perfect battery health. However, as soon as I unplug the power cable, the computer shuts down, just as if i didn't have a battery in the machine.
I've tried both an SMC reset as well as a PRAM reset. No joy - any suggestions?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Sadly, your systems power logic on the main logic board is having problems switching between the two power sources. One of the MOSFETs has failed and will need to be replaced. This often happens in this series.
Time to find someone with good micro soldering skills to fix your logic board.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
So, i guess i'm basically looking at a motherboard replacement? So, even though it was able to CHARGE my battery, it's unable to USE the power from the battery?
No, you need to get your logic board fixed, not replaced.
댓글 달기
귀하의 답변을 추가하세요
David Kim 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 64
