주요 콘텐츠로 건너뛰기
1903년에 설립된 영국의 자동차 제조회사가 생산한 차량 수리 안내서 및 지원.
Corsa VxR repair manual
Dead cylinder 4 unsure why. Rough idle running, zero compression in one cylinder and low in the rest (8 bar)
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@hamzamsj this "zero compression in one cylinder and low in the rest (8 bar)" needs some serious work. You do need theck your valvetrain and your Pistons, head gasket etc. as well as multipole other things. Do a leak-down test and see what that reveals. A compression of zero will cause all the other symptoms you are referring to. Anyhow, I am certain a manual will be available but you need to let us know what exact year and engine size your VXR is.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
It’s a 2013 VXR Nurburgring edition. It’s turbocharged and has a A16LER engine which has a relatively low mileage at 74k
It’s a 1.6L manual engine
댓글 달기
답변을 추가하세요
Hamza Mumtaz 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 203
