주요 콘텐츠로 건너뛰기
Repair guides and support for Gigabyte laptops produced since May 2003.
25 질문 전체 보기
Black screen with vertical lines
Hi there!
So I recently purchased a Gigabyte G5KD laptop (i5-11400H / RTX X3060P) - it’s just over a month old.
I was watching Netflix in bed last night and all of a sudden the screen started rolling blurred grey streaks across it, then went black with nothing but these vertical lines appearing.
As you can see I plugged it into my monitor and it works fine, but the laptop display itself seems to be buggered. I tried resetting the graphics card but sadly I’m starting to think it’s a hardware issue - which is a crying shame considering how new it is.
Any clue what it could be? Is there anything I should do before I start considering taking it to get repaired?
Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Hi
Is it possible to use the laptops Integrated gpu instead of the dedicated one as if you can try that you can tell if it’s a gpu related issue rather than a display issue(if it does it on one gpu but not another you will know what one has the issue buts that quite unlikely)
At the moment it’s looking like a display issue but we need to confirm that by trying the above
Hopefully this helps
Any questions please ask
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Tried adding new ram?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Leigh Ramsay 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 8
전체 시간: 230
